Hello I have a 1776 single port engine on my bus with the OEM engine support
just have to put big washers between the engine and the mounting bar and I use a bugpack street max merged header in order to keep the oem engine support.
My full flow is with a 45° connection after the oil pump and I run with a cumbersome 30mm oil pump
kombiporsche what exhaust are you connecting to your streetmax because i have just bought the same system and i am connecting a mondo muffler to it, the problem is its fouling on one of the pipes and not connecting up properly, they are both bugpack so they should fit.
why not use blu tak and duc tape to fix your exhurst.
much cheaper plus the tape is already silver! it will give you that exhaust wrap drag race look! :lol: :lol:
looking again i was just going to say it looks like the flange is at the wrong angle, i was half asleep when i posted this morning!
sweet exhurst tho dude, like the carpet too! :lol:
With my old beetle header (it does not fit with the oem support, I made a custom engine support that broken in 10 violent starts :lol: ) I made an aluminium spacer , it was clean too.
I cut and rewelded the muffler with my street max header because I did not have the time to make a new spacer...
