who?1
So the engine which I bought my bus with is starting to weep oil. Its a 1600 single port and totally stock. I have replaced the flywheel seals and rocker gaskets but it is either coming from the oil cooler area or push rod tubes. I also found some metal in the top of one head, looked like a rocker shim has started to go south. It also blows a little blue smoke when I let off going down hill etc.
I have no idea how old or how many miles it has covered. I just changed the oil, fitted new plugs, leads, dissy with electronic ignition, oil cooler gaskets then just ran it. Having done about 10,000 miles since I feel I am now on borrowed time.
So should I rebuild the engine in my bus back to stock or pull the worn out engine, a 1641 single port with 110 can and ict's in my bug which is off the road, and rebuild that as a larger fast road? Would a 1776 built for a bus be OK in a bug at a later date?
Any thoughts?
Any thoughts?
