HotVWheels
Guess it's everyones worst fear, stepping on the clutch pedal and with a faint 'click' sound - NO CLUTCH :shock:
Well, friends that is exactly what happened to me yesterday afternoon while driving the Bay, and guess where? At 15:30 on the N1 highway heading South, just before the Rigel offramp at the East of Pretoria. Generally regarded as one of the busiest roads in South Africa, and with the current road works, a nightmare.
Well I limped to the nearest garage after pulling over to the side of the road and starting the Bus with first gear engaged. (Never knew it is possible to change gears without a clutch, but it is indeed. Not easy, but possible, one tends to learn fast with some BIG trucks behind you :shock: The trick is to rev the engine a bit in Neutral, wait for the revs to come down, and then gently slip the lever into gear. )
At the garage I climbed down under the Bus, and much to my surprise found that the clutch cable was still in one piece. OK, release bearing then?
I managed the 60km home by the R21 road on a wing and a prayer (that is past the OR Tambo Airport, and on the R24, another VERY BUSY road), and with some luck and a lot of help from Above I got home before dark. All the traffic lights were green for me when I got to them (first time ever) :shock: and not once did the traffic come to a complete standstill, which would have been fatal for me...
So I took leave today, and started early this morning to pull the engine of the Bus, sequence more or less as follows:
- Disconnect Battery
- Loosen petrol pipe and block to stop flow of VERY EXPENSIVE petrol
- Loosen accelator cable
- Disconnect all electric terminals and unbolt terminals from altenator
- Remove air filter
- Remove rear bumper
- Remove rear valance
- Jack Bus up and support gearbox with stand
- Remove 4 nuts bolting engine to gearbox - OOPS! - top nuts are hard to reach so
- Remove rear wheels to access top engine bolts, and support Bus on stands
- Found that top right bolt loosens from the inside of the engine compartment - DUH - so right rear wheel removed unneccesary
- Unbolt rubber dampers from rear crossmember
- Put trolley jack under engine, and seperate from gearbox
- Lower engine and pull clear from Bus
Well after all the above was finished (and it sounds easier than it was :? ), I had a first look at the release bearing, and this is what I saw:
The release bearing had completely broken apart, and the 2 spring clips were broken too ! No wonder there were no clutch...
What you see below is usually supposed to be 1 piece, with the clips attached to it :shock:
Clutch luckily looked fine, and not damaged. I don't like these '3-finger' clutches, but I'll replace it later
So I jumped in the pool and had a good scrub in the shower afterwards and quickly went to town to get a new release bearing with the wife's car. Luckily Midas had one at a reasonable R 60.00. Got back home, smeared some grease on the sliding tube, and put the new bearing in. I'm not gonna bore you with the replacement sequence of the engine, but it is basically the removal sequence above, in reverse :wink:
Was luckily in time to fetch the wife from work, so the 25 km test drive in peak Friday afternoon traffic, was succesful *sighs relief*
Looking back, what worries me is that this happened quite suddenly yesterday, and except for a faint 'krrrrrrrrrr' sound when the clutch was engaged a few days earlier, there were no other warning that I was due for such a fatal malfunction. Imagine this happening while on tour, you would at least use a day to remove and replace the engine! I'm still a bit worried about the quality of the new bearing, but it was the only one I could get.
- Remove air filter
