Roof seal
Ratty
Jul 20, 2007
7
Grays Essex
Can anyone help?
I am currently restoring a 1969 Luxemburg Westfalia this model has the small pop top similar to those on some westy split screens.
I am trying to work out which pattern rubber pop top seal for the edge I should buy. At just kampers they have more than one pattern.
Do any of you have any suggestions on pattern and any where else such rubber can be purchaced by the metre.
Happy new year to you all thanks in advance.
Ratty 8)
Hi :p
There was not any trim attached when I stripped the bus.
I am guessing it is either this section:
Or this one:
I have found this picture of a westy top on a splitty also:
Many Thanks
Ratty 8)
The bottom one is a westy trim, the top is a universal. its used on devons for the seal between the static fixed portion of the poptop and the bus roof, it can also be used as you need it.
Personally, i would buy the bottom trim its westy specific and you'll get a much better seal (more water tight) when its closed.
