rusty exhaust studs
dagboyblue
Oct 30, 2007
734
Burnham On Crouch, Essex
anyone got any tips for getting the rusty buggers out - this is stopping my rebuild :(
cant grip them enough to twist them out - even when i can they are rusted in solid (even after spraying)
Lock 2 nuts together then use to wind studs out.
Use the longer brass nut when fitting exhaust machine7.com do them, should be easier to get apart in future.
Had the same problem.
Used the double nut method with some and WD40 with mole grips on the others.
Eventually got them all out without having to drill any.
Copious amounts of wd40 and brute strength.
Replaced them all with brass and changed the nuts as well.
try soaking the barrel in a bucket of diesel over night, has very good release properties.
Failing that a gas torch (blow lamp) to heat the stud to a nice cherry red
failing this mole grips
failing this, copious amounts of swearing and brut ignorance .......................................
however the later will almost certainly lead to a need to drill them out :mrgreen:
Weld a nut onto whatever is left ... it gives you something to get onto and the intense heat will free it up.
Hiya dag,
Or..............you could just haul the case halves down to your local machinist shop and let them do the job for you. Of course this is going to a bit more spendy than tackling it yourself but EZ outing a rusty steel stud sitting in a magnesium alloy case can be fraught with peril. I've seen more than one case that would have been (much) better off at the machinist's.
I had a similar issue on my cabrio beetle trying to get the heat exchanger off and that was stopping rebuild.
The exhaust bolts were so rusted and I could'nt get direct access to the bolt head. In the end I ended up getting a hack saw and sawing off the heat exchanger (it was knackered anyway) so I could get direct access.
I used the rachet spanners from halfords for the narrow space.
Nearly two hours with heat exchanger on, 10 minutes with heat exchanger off!! Extreme? You bet! :lol:
Note: cut close to the heat exchanger neck.......its got fins inside :lol: :lol:
