Ok, my van is a 69 lhd with a tandem master. I have been thinking of fitting a remote servo but they are all listed as single circuit, not for dual/tandem systems. But would it be possible to join the two pipes from the master and then into the servo inlet as normal, and run to a 'T' piece split to front and rear with a pressure reg fitted inline to the rears?
I had a Bedford 350 camper that ran a servo and drum brakes all round and they were worked very well, (3.5 tonnes takes some stopping when rolling) My thoughts are that the shoe size and cylinder bores are about the same and I can see no reason why the stopping power could not be improved considerably with a brake booster.
Plenty of room in the engine bay to fit the remote and only a short run from the inlet manifold. Just need to rework the brake lines.
Your thoughts? is it worthwhile pursuing?
