Shaggy
Hello went setting the Choke, what would you class as the full open position, the last tooth is a little longer than the others so is it that, or is it the bit that starts to curve round? hope that makes sense
Now start the engine and warm it up. Take the air cleaner off the top of the carburetory (if it's the oil filled type be careful, you don't want a shoe full of oil) and check that the choke butterfly is standing vertical. If it isn't, run the engine some more to make sure it's throughly warm, and check the choke butterfly again. If it is not standing vertical, the butterfly needs adjusting or fixing.
Choke adjustment on a 34pict3
http://www.vw-resource.com/choke2.html" onclick="window.open(this.href);return false;
