Steve B
Hi All,
So I'm fitting belts to my Single Cab, but have a few queries. It's a single driver's seat and a bench for two - so i've 3-point belts for the outers, and a lap belt for the middle.
The front wheel arches are tubbed, so I'm having the proper plates/captive nut welded in here, so that's straight forward. The upper mounts in the B-Pillar are there, so again, straight forward.
It's a LHD Swedish import, and the problem is, where are the lower mounting points for the passenger and middle seat? The chassis rail on the driver's side, has two threaded points - one for the driver's buckle, and one for middle belt/buckle. But where does the outer passenger buckle and middle passenger buckle/belt go? Pretty much in the middle of the bench seat, but I cannot see any points.
Any help or photos would be appreciated - are they hidden in the spare wheel well? I have a custom amp and Sub built into the well, so not easy to check without stripping down.
Thanks for any replies.
Steve.
Steve.
