Here are the pics. I bolted the webbing using the existing two door bolts behind the plastice cover, cut a small slit in the cover and fed the webbing through. I can slide the door nearly closed, then i just give the webbing a little pull and the door closes with a click.
:mrgreen: This is a picture of mine and the two bolts. This is the rear of the door. The idea is you slide the door nice and slowly so not so noisey then gently pull the rear in to click. The purpose made handle sits on one of these. The one I've seen used both bolts and made a handle very similar to the front in cab closing handles but other way around. I'll make one next weekend, cuz I'm off out now with Mrs Ozziedog.
Ozziedog,,,,,,,,,,,, I've had my instructions for today :lol: :msn4: :lol:
