Do buses actually go at speed ?BrotherNumberOne said:That's not good. Thank god it didn't happen at speed! Did it bend the chassis or shear the bolts on the left side?
I mention it because the problem appears to be the same. Butt welded without any sleeving.
ozziedog said:Second one that wants to know about the liquid,,, What is it? I am hoping against hope that you didn`t spill your Stella
ozziedog said:I`m still trying to work out how that happened, not sure how the forces could be exerted to force that apart even if it was held together with sellotape. The bolts holding the beams plates to the chassis must have come adrift or broke or weren`t tightened to the chassis. Powder coat perhaps ?????.
Ozziedog,,,,,,,,,,,, Glad you`re in one piece mostly :mrgreen:
Trikky2 said:ozziedog said:Second one that wants to know about the liquid,,, What is it? I am hoping against hope that you didn`t spill your Stella
:lol: :lol:
ozziedog said:Just to add to what has been said already, I and others would probably be interested to know if the beam is powder coated especially around the end plates. There have been a few threads of recent years where things like wheels have come adrift where the contact points have been coated with powder coating and have failed under compression even though torqued correctly. Cleaning it off where the wheel nuts/studs contact the wheel and possibly the other side where the wheel contacts the drum/hub surface is one thing, but where do you go with this? Clean off where the bolt heads contact the end plates? But what about where the plates contact the chassis? Is powder coating possibly too thick in some areas?
Ozziedog,,,,,,,,,,,Interesting indeed :? :? :?
