I rebuilt mine recently and its been fine, I had a look at Rob and Daves site and they said this
The VW shops in Australia usually recommend the H30/31 for all engine sizes up to 1600cc (including the dual-port engine), both because the 34s are very expensive here -- almost $400 -- and because the H30/31 is easier to set up. The H30/31 also tolerates the 009 distributor better than the 34 sized carburettor -- less likelihood of flat spots. The H30/31 carburettor has a throat only a mm or so smaller than the 34 anyway, so you should not see any significant drop in power around town (compared to the larger 34) -- it would probably run out of breath a little sooner at high speed and that's about it.
The development of the 30/31 carburettors is interesting... the 30PICT series has a 24mm throat, and it's final development was the 30PICT/3 used in the 1970 1600 single-port engine (in the USA). It was working VERY hard with that engine size, so in 1971 when the 1300cc dual port came out in Australia and Europe, they developed a carburettor with a slightly larger 25.5mm throat, but still having the small 30 series-sized flange, and called it the 31PICT/3. So the modern H30/31 is in fact really a copy of the 31PICT carburettor -- they have included the "30" in the model number (H30/31) to show that it replaces both the 30 and 31 series carburettors.
You can't buy a brand new 30PICT/2 carburettor, but you can buy a brand new H30/31 model, which is the replacement carburettor for all the 28 and 30 series. It has a fractionally larger throat but the same inlet manifold fitting, so you'd get a tiny increase in hp and would probably get a corresponding tiny reduction in fuel economy. The 30PICT/2 is one of the most reliable carbs Solex ever made, and it matches the 1500/1600cc single-port engines very well.
