aogrady
lard said:89Rallye said:Interesting stuff but it sounds like your expecting a 40 year old van to sound like a new car!
I'm doing it more for insulation than sound deadening and if it does kill some noise (which I personally think it will, engine for sure at least) then it's an added bonus.
I have a bare rolling shell at the moment so I'd rather do it and regret it later than not do it at all :lol: £200 is a drop in the ocean compared to what this vans going to cost.
likewise - my primary reason was insulation for the panels - the fact that it may reduce noise is a bonus
I'd be inclinded to do it for noise reduction, with insulation as a bonus, with thin single glassed glass, the heat will go out there, unless you double glaze it. You can put as much insulation as you like in the floors and sides, the windows aren't helping. I'd be surprised if you could tell the difference bettween insulation behind 3mm thick ply on the sides. Cheap soundproofing, cheap insulation, lag your current heater tubes etc and spend the money you have saved on a Propex!
Insulation and sound deadening is tricky, there isn't much that does a perfect job of each, this is why I used the roofing flashing for sound deadening, 2 layers, which vastly improve the "drum" noise, and then loft insulation and silver reflective bubble wrap.
I am also going to use some truck bed liner on the undersides, for rustproofing (though i have already tackeled this) and for it's sound deadening property's, also it'll be body colour. Anything that can add mass to a panel will stop vibrations and noise, jute underlay or similar under the cab carper will help with warmth and soundproofing.
I suspect exterior noise may still transmit, foam is normally good acoustically (and wool) so maybe some closed cell foam, or wool. I think Kinsgspan is closed cell?
Though i may well take it out and redo the side panels in fresh wood, and strip out the loft insulation, and replace with felted sheeps wool, which if wet will dry out, and i can get a large 5kg bag for a tenner.
Have a look at my thread for ideas.
Cheers,
Alistair
