Split/Bay/Bug/Trekker job lots
alex
Oct 7, 2006
77
Preston UK
need this lot gone so im selling the lot's off cheap! they are mainly the parts left over from my projects over the years...
Millitery Trekker/181/182 spares.
Orginal hood material, bush bar's/light guards
front screen surround, sump guard, rifle mounts, 1st aid box bracket, seat springs, door catches , bonnet hindes, dash grab handle, rear marker lights, dash pad, rear veiw mirror, numberplate light seal, lower windscreen fram seal, eberspacher ducting, orginal gearstick... odds and sods
orginal steering wheel, seat belts, spare wheel/tyre, 24V pullly+ brackets, oringinal straps
Split/Bay parts
rust free front beam, stock beam leaves, engine cradle, clutch conduit, good centre pin +new bolt.
2x brand new track rod ends for bay, stock split bus spring plates, rusty stock shifter, wiper blades, 20x bus orginal wheel bolts, late bay dynamo regulator, 68 only ingition housing, early bay steering coloum/cab floor cover, split bus haedlamp rim, duel master cylinder, door handle, bay radio cover plate, split bus wing mirrors/arms, VDO fuel sender parts, crazy non VW wing mirror!
Bug Spares
Late bug air filer box, front flexi hose, earth straps, gearbox strap, 12v headlamp relay, stock camber adjusting bolts, RHD pedal assembly, dash vent, battry clamp, new pedal rubbers
Watercooled/Random parts
mk2 gold headlamps, 12v horn, mk1 golf indicator stalk, hazard switch, BOC argosheild gas regulator, muffler strap, header tank caps, 3 pin master cylinder brake switches, wolfsbergwest frontscreen washer kit, clark mini mig regulator, and .6 tips. chrome universal centre cap/ with mouting kit.
Stock Air Cooled Engine Parts
exhaust packing, tail pipe extension, 31 pic1 s/p carb/mainfold, dynamo stands, rocker covers, s/p head tins
oil pump cover plates, sump plates, rear tine s/p, stock size german 69mm crank needs re-ground.. under tins, t/p doghouse cooler tin, 1300 barrels n pistonsx4
oil dip sticks, m10 head studsx 20... stock rockers from 1300/1600, stock cam, t/p inlet manifolds 1600's
t/p inlet mainfold for 1600's, 1x 1600 t/p head, 2x 1500 s/p heads, 2x 1300 s/p heads, stock 12v coil, coil mount
Bus chassis rail notchs + bug/split 4stud to wide5 spacer rings for swing axle gearboxes
bus wide5 2x 14" suit rat looker...
Now when it comes to pricing... id take £300 ono for the lot, for seperate pricing on each item PM me
all parts located nr Preston NW UK
still got most of these bits... woudl take serious offers on the lot!
cheers
alex
