Split charge relay going bonkers
Mags
May 22, 2009
519
2
I fitted my leisure battery today and used a split charge relay that I used to have fitted years ago before my resto, I followed wiring diagrams I found online and I still have a dynamo so it seems the relay activation wire goes to the generator light output/the smaller post on the dynamo, however at lower revs/idle the relay is going bonkers just constantly switching/clicking like mad.
I'm not familiar with the output of the dynamo but it certainly isn't putting 12v out of the small connection so how do I measure this output and have I wired the relay to the wrong post?
On the pic below it goes to the right side post.
You need to put it downstream of the regulator - that should sort out the switching issue!
Cool, thanks, will give that a go next weekend. So I take it I just need a 12v once the engine is running?
No! You were correct except that you have used the wrong terminal. Connect the relay terminal (usually marked 86) to the D+ terminal of the dynamo - the one on the LEFT of your photo - not the right hand side one.
Peter Good
Peter Good
Ah, thanks Peter.
