2nd opinion needed. Van seems to turn over slowly and I have to crank it twice to get it to start. Is this the symptom of a starter motor on way out or not enough power coming from battery. Battery is 400 CCA. Cheers
Have you cleaned up the terminals on the battery? Also check the earth straps. I would be tempted to put the battery on charge and see if that makes it any better. Easy things first
