5erge
Where can I buy one or does anyone have one in the London area that I can borrow?
Des
Des
Loxy said:Try using your knees to lever the wheel when sat on the seat along with wibblers loose nut on approach (assuming you are reasonably tall)
Bookwus said:Hiya 5erge,
Hah! I'm always amused when I read about steering wheel removal. There's always the suggestion of pushing up on the wheel with your knees. Man! You'd have to have the legs of an NBA center to do that. I'm 6'1" and waaaay short to accomplish that little trick. Besides no amount of "leg effort" would ever budge my steering wheel.
Loxy said:........I'm 6'2" and I managed to get my steering wheel off with my knees (although I cant remember if I was using wooden blocks :lol: ), was a proper tight fit needed some penetrant spray and a good few minutes of pressure
Sydney1 said:I used the puller from Screwfix but you will need to find something to protect the base of the hub as the puller arms have a habit of slipping off and the plastic is easy to damage.
