Telford Mulisha
Unable to cure misfire after changing the usual suspects, did a compression test and got the following...
No.1 - 60psi
No.2 - 60psi
No.3 - 0psi
No.4 - 30psi
So dropped the engine to check heads, a bit sooty around the top suggesting a leak. Had the heads inspected and cleaned, new exhaust valve guides bushed as they were worn and valves reseated. Fitted new piston rings, barrels still have honing marks on and nothing else wrong really.
Fitted head on one side before running out of light last night, now...
No.3 - 20psi
No.4 - 30psi.
Should I be doing a compression test by turning the engine over? Are the readings lower by winding the engine over by hand?
Any engine builders have any thoughts?
Sent from my SM-G920F using Tapatalk
No.1 - 60psi
No.2 - 60psi
No.3 - 0psi
No.4 - 30psi
No.3 - 20psi
No.4 - 30psi.
