Throttle linkage
T2 Brinky
Oct 21, 2011
456
309
cardiff
Hi all
What are you using?
Pros and Cons?
What have you had in the past?
What they linked up to?
Pics are always brill. Been warned off the Hex bar style but see them used regularly.
Cheers in advance
I like the look of these but welcome your thoughts?
    785.3 KB
Had the hex bar myself for quite a while. Wasn’t until I had the motor out of the noisy cupboard and on the bench for splitting (cam thrust) that I realised mine had worn more on one end than the other in those nylon bushes, then I could see that both carbs couldn’t operate the same at the same time although it appeared that they did. Had a linkage set very very similar to your pic and it’s been great for about four years so far. Mine came second hand and unused from a forum member (Toffo) and I just had to change a rose joint for some reason or other.
Ozziedog,,,,,,,,looks fab bud :)
I have the CSP Bell Crank linked up to Twin Webers along with Butty’s Bits Full (through chassis) linkage kit, a new Pedal a new pedal bracket and a new cable.
