now some of you might have read a thread of mine about whining,well i changed the gland nut and it still whines :evil: :evil: last year had a new clytch release bearing put in but i guess perhaps the bearing has failed cos the engine still whines when warm and clutch pedal depressed even after backing off cable so not much pressure is applied if you see what i mean?
now i have got another new release bearing of german quality from machine7.
so my question is .........
being a bearing what grease's or lubes the bearing???is it a sealed unit?does it need lubing?? if you do does it effect the clutch?
is that what is causing the whine?
last time i checked it fitting the gland nut the bearing was clean and dry,should it be lubed?
sharky:bliss:
sharky:bliss:
