Hi Alistair,
I'm toying with the idea of painting the whole of the bottom half of the van that purple colour with the metalflake..... still can't make my mind up. I know the 'purists' will be frothing at the mouth at that..... after painting the fan shroud and seeing the results (photos don't do it justice) i'm now considering that also. (thats a vauxhall metallic Anthracite with the lilac chameleon flake)
Anyways, got the oil back in today, and been for a run out tonight, but before I did, I took a trip to my local garage where I get the vans at work serviced, and got the carbs dialled in a little better using their exhaust gas analyzer.
Still got a couple of gremlins tho.
1) won't run unless the timing is 18 deg btdc at idle - (can't think it was like this before, i'm sure it was 7.5) - showing around 40 deg at around 3500. I'll be pondering this one for a while, can't think what is causing this, but it just won't run at any less. I'm wondering if the Scat crank/BMD Pulley pairing has thrown the timing marks out.....
2) got a flat spot at around 2k rpm, but, I'm only drawing vacuum from one carb, and by the look of it, that is only tapped into one barrel. I'm running the 123 dizzy with vac, so i'm thinking that its not getting enough/intermittent suction from the one pot. I'm going to try drawing vac from the other carb so got a couple of non return valves and a t piece on order to see if this makes it any better.
3) When ticking over, 1,2 and 4 all read around 3.5 on the sync gauge, but no 3 is about 2.5, and doesn't change at all when adjusting the idle screw. I'm going to have to take that one off and have a look see what is happening there. Might have to put the leakdown tester across the cylinders to see what compression i'm getting.
All in all tho, I'm happy with the results, got loads more power than before, just want to get it nearly there before I take it down the rolling road (last time they revved it to within an inch of its life, don't want them doing that before its had a bit of running in.)
All the best
Mark
All the best
Mark
