swartie
is this an engine out jobbie to replace the bottom pulley?
speedwell68 said:I've just invested in new genuine VW Brazilian style fan type alternator pulley as it helps draw heat from an internal regulated alternator. On the bottom pulley I have an EMPI drilled alloy one as it was cheap and my old stock one was all bent. I'll post some pics later.
slammedkustom said:top tip for ya all
mark the TDC, BDC and 7 1/2 timing mark on the rim with a sharp screwdriver and a tap from a hammer.
that way if your fanbelt flies off and takes out the numbers on the bottom pulley you can still use the pulley. :lol:
