noddy
Have you checked that you are getting a spark at the plugs? Coil, condenser, plug gaps, points gap ok? Timed on number 1 cylinder, plug leads on in correct order.
Did you clean carb with carb cleaner to get crap out of all passages, is the engine even trying to start but failing to keep going?
What carb are you running?
If your carb has an accelerator circuit you should be able to see it pumping fuel into the carb when you open the throttle by hand (engine off, little tube pointing down into center of carb on solex), this will at least tell you if fuel is getting into the carb.
Is the engine starting but stumbling popping etc.
If you have fuel at the carb venture and a good spark at the plug, it is going to be either tuning i.e. timing way off, plug leads in wrong order etc (usually will pop and bang in on in wrong order).
Ian
Ian
