Twin carb 40idf
Paulwhite68
Sep 6, 2015
20
I have a 1600 twin port engine, and was going to do a 40idf twin Webber conversion. Will this run ok or should I be thinking more about running a larger engine first! Thanks
40's will work fine. Up to you if you want to splash out on a bigger motor but it is not necessary if you just want to use the carbs. Make sure you get the right chokes though else they will have a flat spot. 28 ur 30mm should be about right.
I had 40's on a 1641 with a 110cam it was good in my double cab.
Currently running 34ICT dual carbs on a stock motor in my bug, they work great and really made it come alive, plus much cheaper!
