Beetle engine build
67panel
Jul 30, 2009
2,797
213
malven
Year of Your Van(s)
1968
Van Type
panel
Having a clear out and fund raiser, dragged that 1300 Beetle engine out and stripped it down. Found I have enough stuff to rebuild it , bearings, 1679 P&Bs ,110 cam, new rear seal and push rod tubes and gaskets. 1600 twin port heads , vac or 009 dist and either 31 carb or twin Webber 36IDF carbs. Only bit I am short of is a crank pully.
I forgot how hard it it to clean the case 1/2s, been sat 20 odd years and still had the dried on crud from the Beetle!!! 4 hours with a small wire brush, screw driver and 3 pots of Jizer
Come down with a stinking cold so not touched it, well at least it will have dried out when I get to it.
Back on it after Crimbo as need to get it done, also have to finish the panel. Entered my hot rod I am building in a show at the 3 Counties in April and not going to be finished but have to get as much done as I can.
Well thats a bust, casing is scrap due to wear at thrust main bearing. Anyone want any bits? 110 cam, used 1679 P&Bs and 1600 twin port heads.
You ain’t having a lot of luck with it lately bud. I’m home with the same Chrimbo lurgey as you possibly had. My ribs are aching from coughing and my tum muscles think Mr Tyson has been working out on them. This is getting to be a regular Chrimbo event for me.
Ozziedog,,,,,,,,, sad old fart syndrome for me I think :)
WOW, seems a load of people have it. Feel the same way Ozzie.
J & P
:D:D:D:D
Yup, was going down the unit but still coughing a bit. 2C is a bit to cold for me!!
In case it’s any help to anyone coughing and spluttering until your ribs try and break free from your chest 🥴
Gargling with Listerine all around the back of your throat two or three times a day , well that almost knocks out the coughing, not completely but ninety five percent of it. Gets you through the night too. Or, it might just help me.
Ozziedog,,,,,,,,,,,,hope it gets some relief to someone. :) ;) :)
I am almost sorted Oz, over slept big time this morning as it was 10.30 when I came around!!
S.O.F.S. Is exactly what I’m gonna call it from now on. I’m there already, you’ll be there in a couple of years Pip won’t get there as she is way too nice.
Ozziedog,,,,,,,,, S.ad O.ld F.art S.yndrome :)
Spent Chrimbo doing the same as you, however someone else you know had it very briefly and gave it to me.:rolleyes::rolleyes:
Can't really complain can I ??:ROFLMAO::ROFLMAO: 2 days off and a chest thats dying to explode on the next cough.
And some one else is fine and dandy.?? Fair??
Keep well all.
J & P
:D:D:D
Similar indeed. I’m feeling ok now and the cough is just about gone. Just feeling very achy breaky and mired in tired that’s for sure. Can do with a bit of help to get me into second gear as I’m just trundling about closing in on auto pilot right now.
Ozziedog,,,,,,,,,,, Kick up the chuff is maybe required :)
