Firstly I have been given a FlameThrower coil and although I understand it is a straight swap for my current coil, the instructions suggest I need to check if I have a resistor in place :?: ... Can anyone tell me firstly if my van would have one (UK RHD 1972 Dormobile, Type 1 1600 VEGE engine), if it has or if no-one knows where should I look to locate it?
Secondly is in regards to my leisure battery set-up. My stereo runs off the leisure circuit which is a 85amp/hr deep cycle battery with split charge system running through a domestic fuse box to the stereo (also controls power inverter and interior lights) However, when I start the engine it always trips the fuse from the leisure battery - the main fuse not just the stereo circuit... Can anyone suggest why, or what I should check to stop this happening? :?
Third question, I know I said two but while I'm at it :wink: whenever I put the van in reverse gear the ignition fuse (2nd from left as I remember 16A) blows. This orginally happened when I put the n/s reverse bulb in which I subsequently removed but now it happens all the time, do I just need to check connections around the bulb, bulb housing? Or should I check elsewhere? And why is it the ignition fuse that blows? I say its the ignition fuse as when it blows I have nothing on a turn of the key - gen & oil lights don't come on, fuel guage doesn't spring up...
Your help as always much appreciated :mrgreen:
