Type 3 Wheels
They do indeed dood 8)
My early notch ones fit straight on. Only thing is you cant get domed hub caps for them so wont be able to get a hub cap to fit over the rear castle nuts. If you are not running hub caps then thats cool 8)
Sweet cheers, and also can you give me a rough idea what the difference is between 15" stock split rims, and 15" crows feet. Does the look of them on the van look any different or do the tuck in more?
I think they look the same and the tuck is the same. Im not 100% tho sorry dude. 8)
Type 3 rims have the best tuck of any stock wide 5 wheel. 8)
mattd1984 said:
So they'd fit on sweet? just couldnt use hub caps?
Yes, theyll fit, and like Slammed said, Type Three wheels have a better offset than bug or bus.
Im not sure about the hubcap thing ... I thought domed caps would fit on, but maybe not? :?
Some domed hubcaps will fit, I got a new set for my old Notch, problem is they won't fit over the hub nut, as Easy said.
I get it, its that damned rear nut :evil:
I guess some spacers on the back may resolve that, leaving the fronts tucked away nicely?
Yeah, but you may as well just put standard bug or bus wheels on the back.
bananacustard said:
Crowsfeet have a pressing like a crow's foot around the bolt holes.
This is true, unless you bend down and look close up you would never tell the difference. They fetch a little more gold than stock split steels too :|
