ballbag
I've just replaced my fuel sender and the gauge worked fine
Then it started to flicker so removed the clocks etc and the connection was loose, fine I thought but when I put it all back, one of the indicator lights failed so I removed it again and the cable had come off :roll: .
After putting it back the horn stopped working and the wipers were really slow :? , then the indicators stopped completely and the hazards only work with the ignition on :? .
Now all that is working is the lights and the starter wont turn, just clicking.
I've checked the battery and there is just over 12v on it.
What I did notice is that when the hazards were clicking away that it was a very weak click, if you no what I mean? Sam with the indicators and they were not working at all on the outside but when I tapped the black box behind the dash it tempararely worked.
I removed it at the back fell off so I put it back on and re fixed it in position, could it be the box?
I really need to get this fixed as I am supposed to be driving to T2D on friday for my lowering job.
Any help would be greatly received.
regards
Jay
regards
Jay
