aogrady
Hi!
I bought this a little while ago, but have not fitted, I've changed my mind and will fit a blanking plate instead. It has MW and LW and I believe quite a high end unit back in the day
It's a lovely looking unit, in good condition for the age, working condition, maybe rubber belt replacement if used regularly due to age
Sizes:
Overall width of unit = 176mm
Overall height of unit = 48mm
Overall depth of unit = 148mm
Overall depth including knobs = 189mm
Distance between knob spindle centres = 130mm (adjusted to min dist - they will adjust about 8mm out each making the dist between knob centres 146mm. The fascia plate fits as is at 130mm centres but I guess you could elongate the holes if needed)
Width of centre "box" (the bit with the tuner scale / cassette door etc) = 89mm
Height of centre "box" = 39mm
Width of plastic fascia plate = 182mm
Height of plastic fascia plate = 50mm
Looking for my money back, so £40 posted please
Cheers,
Alistair
Sizes:
Cheers,
Alistair
