First three being 211 is bus stuff
Treasure hunting with Classic Volkswagen Parts: New Old Stock parts from Paraguay
It is the find of the year: The stock of Volkswagen importer slumber in Paraguay since 1953, real treasures - Volkswagen Classic Parts Replacement parts makes these rare now accessible to European customers. Between February and October 2012, we expect two or three shipping containers with more than 2000 spare part items.
A list of available back then little by little parts we want you already provide. We appreciate your understanding that not all items listed here are available immediately. For price inquiries, orders and more information, please contact only to the following e-mail address:
[email protected]
Please note that these are New Old Stock parts are bearing traces, some of only in small quantities are available. Sold only in small amounts are subject to change without notice.
The following spare parts we can offer you as part of the action:
Part Number
Designation
001301085A
Support
002311101A
Drive shaft
002311523
Needle Roller Bearings
002311523A
002311531A
Wheel
002517157A
Bevel
003321371
Seal
003323571D
Converters
016311575B
Shift rod
021115451B
Oil filler
Part Number
Designation
021119367
Warm air guide
021129607H
Air filter
021129608
Control box
021129917D
Bracket
021129929
Lever
021199231C
Rubber-metal bearings
001 022107111M
Piston (blue)
025251053B
Silencer
028103603A
Oil pan
028105505F
Crankshaft bearing shell
028105535G
028105701A
Big end bearing
028107393A
Piston ring
028121035B
Water pump
028121035C
Water pump
028129625B
Seal
028129705B
Suction
028198183
1 set of piston rings
028198653
1 set of clutch plates
055198569
Set of seals
061103603
Engine oil pan
061121253A
Water Cooler
061129612
Saugkrümmer
068121253A
Water Cooler
068129673
Holder
070129608
Control box
070129608A
Control box
070198569
Gasket set for carburettor
070199231
091301183
Storage ring for Differential
091311515
Return wave
111101127
Seal
111101149A
Oil pipe
111101193
Stopper
111101199
Stopper
111101341A
Seal
111101343
Seal
111101343A
Seal
111101381A
Ring
111101385A
Compensating ring
111101387A
Compensating ring
111101403A
Leadership
111101406
Leadership
111101408
Leadership
111101417B
Leadership
111101420A
Leadership
111101461
Disc
111101487
Clamp
111105599
Crankshaft bearings
111105707A
Big end bearing
Part Number
Designation
111107111CG
Piston
111107355Z
Piston ring
111107361
Piston ring
111107361B
Piston ring
111107365
Piston ring
111107369
Piston ring
111107431
Piston pin
111115411
Piston
111115411A
Piston
111115421A
Spring
111115425A
Spring
111115431B
Screw
111115487
Seal
111141161C
Shell
111198451
1 set of crankshaft bearings
111198453
111198465
111198467
111198469
111198471
111198473
111198555C
Set of seals
111199101
Hammer screw
111199103
Hexagonal screw
111201261
Clip
111209139
Seal
111209147A
Sieve
111209159
Mother
111209189C
Spout
111251221
Seal
111251223
Cone
111251233A
Cone
111251241B
Seal
111251263A
Seal
111251267A
Clamp
111255281
Bolt
111255285
Hexagonal screw
111255309B
Connecting piece
111255311
Bolt
111255413
Clip
111255416F
Heating pipe
111255500 041
Baffle
111298005
1 set of mounting hardware for pre-silencer
111307125
Deep groove ball bearings
111307219
Camp
111307541A
Gear lever
111405486A
Disc
111413381B
Rubber bearings
111413401A
Hexagonal screw
111415131
Cover
Part Number
Designation
111415155
Support bracket
111415159
Locking plate
111415159A
Locking plate
111415251
Screw
111415371A
Steering lever
111415381
Bolt
111415385
Locking plate
111415421
Screw
111415521D
Lock shell
111415539
Clamp
111415543
Sheet
111415603B
Rubber bearings
111415609
Guard ring
111415611
Support bracket
111415621G
Support
111415691
Mother
111415811
Tie Rod End
111415841A
Clamp
111498121
Repair Kit
111501105
Rear-axle
111501131A
Seal
111501133A
Seal
111501141B
Bearing cap
111501151
Joint Case
111501311
Cover
111501311B
Cover
111511221
Cover
111517169
Ausgleichkegelrad
111517185
111517213
Disc
111698173A
Repair Kit
111701255B
Shift rod guide
111701415
Bolt
111701535A
Bracket
111707121
Spacer
111707193
Seal
111707197B
Seal
111707333
Bumper beam
111707334
Bumper support
111711121G
Gear lever
111711145B
Compression spring
111711149B
Stop plate
111711305A
Hand brake lever
111711339A
Toothed segment
111711671A
Axis
111711675
Cap
111711677
Spring washer
111711711B
Lever
111721335
Clutch
111721335A
Clutch
Part Number
Designation
111721335C
Clutch
111809379A
Clip
111809571D
Catch tray
111813705A
Seal
111813707
Seal
111819941
Warm air hose
111819942
Warm air hose
111821531A 620
Covering
111823301C
Hinge
111827311B
Hinge pin
111827329
Spring
111827331A
Spring
111827573B
Lock cylinder
111831052E
Door
111837016D
Door lock
111837036B
Platen
111837418C
Guide rail
111837502B
Windows
111837502K
Windows
111837529
Seal
111837561
Lift rail
111837562
Lift rail
111837602F
Hung windows
111857305
Ash body
111857543
Base
111857795 581
Aperture
111881251B 043
Button
111881991
Arretierungsklammer
111903213C
Claw
111903225
Disc
111903237
Intermediate ring
111903353B
Field coil
111903505 a
Cap
111903505Z
Cap
111903515C
1 set of carbon brushes
111903519A
Compression spring
111903537
Shield
111903565
Disc
111905271A
Vacuum unit
111911341
Bush
111911343A
Guide ring
111911365
Engagement lever
111911383
Cylinder screw
111911461
Disc
111911471
Disc
111911477
Disc
111911479A
Ring
111911485
Snap ring
111915405B
Cover
111937135
Clamping screw
Part Number
Designation
111937505G
Fuse box
111937505M
Fuse box
111937555
Fuse box
111941129
Seal
111941145
Threaded plate
111941147Z
Rubber bush
111941191
Seal
111941197
Spacer
111941341
Flat socket housing
111943111H
Housing
111945263F
Bulb holder
111945265
Lampholder
111953559C
Camp
111953561
Insulating
111953562
Insulating
111953563
Snap ring
111953572A
Spacer
111953575
Spring
111953575A
Spring
111953577
Slide
111953631
Housing
111953633
Housing
111953635
Housing
111953635A
Flat socket housing
111955407E
Wiper arm
111955408A
Wiper arm
111955408K
Wiper arm
111955453
A liquid container
111955511B
Switch
111957801J
Speedo
111971511
Potential distribution
111971905
Spout
111971907
Spout
111971911
Spout
111971921B
Plug housing
111971938
Splices
111971939
Splices
111971943
Flat plug
111971945B
Lug
111971950
Lug
111971951
Angle Receptacle
111971962
Flat plug
111971962A
Flat plug
111971965
Angle Receptacle
111971966
Elbow sleeve
111971977
Flat plug insulator
111971984
Flat plug
111971986
Blade housing
111998107A
Hazard warning lights
113101111
Dowel
Part Number
Designation
113101112A
Stopper
113101125
Seal
113101131A
Mother
113101139
Stud
113101145A
Bush
113101157
Cap
113101175
Hexagon nut, self-locking
113101217
Seal
113101221B
Oil deflector
113101341
Seal
113101343A
Seal
113101381A
Chock
113101385A
Chock
113101385F
Compensating ring
113101389A
Compensating ring
113101397
Stud
113101397A
Stud
113101397B
Screw
113101398
Stud
113101399
Screw
113105569
Crankshaft bearings
113105725
Big end bearing
113107351
Piston ring
113107361
Piston ring below
113107371
Oil ring
113107411
Piston pin
113107431
Piston pin
113109015G
Camshaft
113109017G
Camshaft wheel
113115349
Blind flange
113115451
Filler pipe
113115451D
Oil filler
113115475
Seal
113115495
Hollow screw
113127171B
Housing upper part
113127189
Seal
113129109
Carburettor housing top
113129701AP
Intake manifold
113129701K
Intake manifold
113129707
Seal
113198011
Seal kit
113201215
Seal
113201221A
Pipe
113201225B
Sieve
113201227A
Filler pipe
113201275B
Hose clamp
113201281B
Shield
113201291
Seal
113201293
Screw
113201337
Seal
Part Number
Designation
113201399
Spout
113201557A
Seal
113201557C
Seal
113201701
Fuel separator
113201709
Spring
113251163G
Exhaust tailpipe
113251163H
Tailpipe
113251225Z
Support bracket
113251263
Seal
113251263B
Seal
113251273
113255107
Heat exchanger
113255271
Tension
113255483
Aperture
113255529C
Cap
113255530C
Cap
113301031B
Housing
113301185A
O-ring
113301193
Disc
113301204
Switch housing
113301205
Switch housing
113301215
Seal
113301217
Seal
113301219
Seal
113301265A
Rubber bearings
113307155
Ring
113309141
Bush
113309219
Camp
113309219A
Camp
113309225A
Disc
113309227A
Disc
113309231
Spacer
113309241
Ring
113309265
Bush
113309295
Synchronous ring
113309309
Synchronizer
113309515B
Axis
113311105
Drive shaft
113311243B
Synchronizer
113311251A
Gear
113311251C
Gear
113311265B
113311271A
Spacer
113311273
Disc
113311341C
Gear pair
113311507
Drive wheel
113311507B
Drive wheel
113311519
Belleville spring
113311551A
Shift fork
113311557A
Shift fork
Part Number
Designation
113311561C
Shift fork
113407311F
Knuckle
113415205A
Steering spindle
113415375
Locking screw
113415389
Hexagonal screw
113415390
Hex nut
113415393B
Bracket
113415501
Steering tube
113415501D
Steering tube
113415511
113415527
Shell
113415531
Snap ring
113415575A
Bellows
113415585
Bearing
113415585A
Bearing
113415587A
Compression spring
113415593A
Disc
113415661C
Retraction collar
113415673C
Compression spring
113415769
Holder
113415837
Clamping ring
113415949
Locking plate
113501157B
Hose clamp
113501231
Wheel shaft
113501327
Belleville spring
113517121D
Differential housing
113517143N
Pinion and ring gear
113517143R
113517145B
Hexagonal screw
113517211
Shim
113517215
Shim
113517283F
Flange
113517285B
Joint flange
113609139A
Brake support
113609140
Brake support
113609439C
Brake mounting plate
113609439E
113609440C
113611053
Wheel cylinder
113611055
Wheel cylinder
113611301G
Reservoirs
113611301M
Reservoirs
113611381
Sieve
113615107B
Calipers
113701173
Plate
113701293C
Seal
113701329
Deformation element
113701409A
Sheet
113701571
Seal
113701571A
Seal
Part Number
Designation
113701605
Seal
113707133A
Bumper support
113707154
Bumper horn
113707195
Piping
113707217
Rubber strip
113707219
Cover
113707391
Support
113707392
Support
113711125D
Gear lever
113711305
Hand brake lever
113711341
Bearing bolt
113721315C
Kupplungsfußhebel
113721335
Clutch
113807130
Spacer
113817295C
Cover
113817297A
Seal
113819448 043
Aperture
113819448A
Aperture
113819456
Molding
113819539A
Water drainage pipe
113819661F
Button
113823299
Profile
113823337B
Support spring
113823337C
Support spring
113823565F
Handle
113827077
Water drain hose
113827083
Protection Profile
113827503
Door lock
113827503H
Door lock
113827573A
Lock cylinder
113837206
Door handle
113837409A
Guide rail
113837640A
Quarter
113845521Z
Seal
113847135Z
Seal
113847139
Plate
113847205
Seal
113853241A
Molding
113853309B
Sleeve
113853345B
Molding
113853515B
Molding
113853526A
Molding
113853535A
Molding
113853536A
Molding
113853536B
Molding
113853585
Clamp for trim
113853585B
Clip
113853615
Spout
113853615A
Spout
113853687
Logo
Part Number
Designation
113857219
Seal
113881177B
Spring
113881179
Indexing plungers
113881179B
Indexing plungers
113881245B
Tension
113881247
Conduit Clip
113881265
Clamping spring
113881317D
Seat frame paneling
113881581
Lever
113881607A
Aperture
113881621
Stopper
113881693B
Torsional
113881699A
Lever
113881899
Nail
113881899A
Screwnail
113885553
Buffers
113903213A
Anchor
113903213C
Anchor
113903351A
Stator winding
113903351D
Field coil
113903351E
Field coil
113903351F
Field coil
113903351G
Field coil
113903353B
Field coil
113903353D
Field coil
113903353F
Field coil
113903505B
Shield
113903515
113903537
Shield
113903537A
Shield
113911115
Field coil
113911255
Housing
113911311
Anchor
113911335C
Freewheel gear
113911335D
Freewheel gear
113911457
Ring
113911461
Disc
113911465
Seal
113911467
