Nope it's solid on the other side, I'm thinking the only option might be to drill it out. Not a very tempting thought as I don't want to wreck the handle......Trikky2 said:Yes, looks like a pin. Can you drive it out from the other side?
Why not try cutting a slot in it and seeing if it will unscrew? Might be a screw with the head chopped off67westy said:Nope it's solid on the other side, I'm thinking the only option might be to drill it out. Not a very tempting thought as I don't want to wreck the handle......Trikky2 said:Yes, looks like a pin. Can you drive it out from the other side?
Is the thread on the barrel rather than the handle casting?
Sent from my Nexus 6P using Tapatalk
Good point, worth a try!pkrboo said:Why not try cutting a slot in it and seeing if it will unscrew? Might be a screw with the head chopped off67westy said:Nope it's solid on the other side, I'm thinking the only option might be to drill it out. Not a very tempting thought as I don't want to wreck the handle......Trikky2 said:Yes, looks like a pin. Can you drive it out from the other side?
