I'm ready to build up a new motor for my bus and I want it to be correct for the year - 1969.
This means a B code 1600 single port I believe. It currently has a later twin port motor.
It's a step backwards I know but it is a restoration.
Complete engine would be good- running or not
Otherwise, parts I need are:
Complete B code short block - the less machining it's had the better
Oil cooler, fan shroud and fan / generator & pedestal, fuel pump
Upper tinware - cylinder tins, rear tin and pulley surround
Vac only distributor - code 113 905 205 T (or M or K) or 131 905 205 (I think these are the correct options for a 30 series carb)
Okay, that's virtually a complete engine but I do already have the heads, inlet manifold and a few carb options.
What have you got?
What have you got?
