james309 said:Thanks I'll give him a try.
I have a box ATM, but any adjustment makes the steering tight.
james309 said:As per title, need a steering box, in good order for my 68 bay.
Anything about ?
James
Thanks will give it a whirl !ozziedog said:james309 said:Thanks I'll give him a try.
Sounds like the peg is binding on the worm, where you get the most wear is straight ahead and just a little each side, gradually the peg wears into the worm and it`s the worm that we can`t get replicated, some one reported success with a modified peg. But I`d go for a recon and they`ll use the best bits you can get. Don`t know if this will work but you are between a rock and a hardplace. There is a liquid grease available for steering boxes etc, it may just have a little more body to it to make adjustment possible, it`s got to be worth a shot. Don`t use regular grease that`ll give you worserer issues, I`d get some, drain the steering box, fill with liquid grease and try it.It sounds like it can`t be worserer :mrgreen:
Ozziedog,,,,,,,,,,,,,,,,The Holy Grail :mrgreen:
Dub and Bubber said:james309 said:As per title, need a steering box, in good order for my 68 bay.
Anything about ?
James
About to "extricate" a box (RHD) so not bench tested for play yet ...
What's your budget for one with little or no play in it?
Dub and Bubber said:£150 seems to be the figure ...
Where are you?
james309 said:Dub and Bubber said:£150 seems to be the figure ...
Where are you?
Do you have one ?
