Wasted £100 on new Westy tap/pump
Ronin
Jul 12, 2010
49
Where the Cider drinkers come from
Just got round to fixing the leaks and replacing missing pipework on my Westy sink unit and fitted new tap/hand pump, not sure why I bothered spending £100 on a new one as I can spit more than comes out of the pump, i guess it would take a good hour plus to fill the sink.
Also wasted £18 on a new Westy sink plug which doesn't stop the water from going down the drain (will have to pop to £ shop to get a universal plug).
Is it possible to retro fit an electric pump to supply water via the standard tap?
A good Westy tap pumps water well, are you sure it isnt pulling in air somewhere?
Maybe pulling some air in then as i had to prime the pump to get it to pull any water from the tank and definately sounded like it was gurgling a bit, might have to try a get a hoseclamp round the top of the pipe.
Also had a bit of water leaking out of the handle (maybe i need to rebulid the NEW handle and replace the gaskets).
