aogrady
Hi
Having a massive clearout of stuff i;m not needing any more.......or will never get around to fitting :lol:
Can post some bits, or collect in Instow, North Devon or a show. will be off to Dubs at the Castle..........
Westy louvre windows for refurb. Control works, bit stiff as has been standing, all glass intact, .Will clean up nice. Also x1 mozzy net frame included
£80 PENDING
Red wheel inserts - note, these will need some fettling to fit, they are for 14" I did get it to fit one ok, but they are tight, some trimming on the inner would do perhaps, and some decent clips, which i haven't got.
£15
Stainless steel Rover P6 wheel trims. In my wisdom, i was sure they would fit a early bay, as i had seen some, but maybe was late? Dunno. Anyway, 14" fitment, would look cool on a retro ride, maybe slammed golf?
£20
Kiensle clocks x2 Think type 3, 6V? One looks really tidy, other one manky, no idea if they work, so sold as spares or repairs. You can fit these in a bay with some mods.
£25
Ball joint and track rod end, no boot on the ball joint, both German quality.
£10 pair
Roofrack trinkets! Retro suitcase, large size, locks work, handle needs a little fix to secure. A few retro stickers on it.
£10
Alloy lightweight drinks container, will polish up awesome, 2 small dents on side, crack on inner lid - would araldite.
£20
x2 ratty pattern caps, sand and paint em grey like a stock commercial
£5
Door cards, tatty, but useable, 6x9 grill fitted, recently got from forum member, but again, change of plans. I was gonna soften the rear hardboard, and peel off the OG covering onto a new card, and get my 6x9's off the floor!
£10
Bolt on rocker cover with fixing kit, alloy will polish up, with cork gaskets
£15 PENDING
Heat riser replacement pipes.
£10
Eberspacer I think, timer, could be used on propex or suchlike? Again untested, straigh on front.
£10
That bit to weld onto a bug tin to fit bus, you know, the hard to find part. I have since found another tin, mainly as i wouldn;t be able to get it weldede, though i am sure it could be pop rivited.
£18
Rev counter Porsche 924, one has broken glass, again untested, but would look cool somewhere.
Both for £20
Picnic hamper - melamine plates and bowls, quantity of knives and fork, 2 large plastic wine glasses etc
£10
Sony CD RDS head unit and Harmon Kardon ipod control with joystick and LCD screen. Charge and conrol ipod. CD has pre out IIRC, works fine, just upgraded. Ipod can be plugged into aux thus bypassing the FM modulator.
http://www.amazon.co.uk/Harman-kardon-Drive-vehicle-built/dp/B000DZ834W" onclick="window.open(this.href);return false;
I had a slight hiss on the ipod bit using the built in fm bit, but it could have been my wiring skills! When i used a external fm thing on the ipod it was fine, though as mentioned, you could use the aux input on the control module.
£40
Retro cooler boxes, good nick inside. Bought big cooler now, don't need these. I'm sure i'll regret selling them,as they are a great size to take to beach
£10 each
Alloy/stainless steel race motorbike exhaust, would be awesome on a buggy, or modify your bus or bug header.
£80 the lot with fixings etc.
2 burner grill and hob, been around a bit, needs clean
£10
Cheers!
Alistair
£80 PENDING
£15
£20
£25
£10 pair
£10
£20
£5
£10
£15 PENDING
£10
£10
£18
Both for £20
£10
£40
£10 each
£10
Cheers!
Alistair
