what size tyres???
mk2matt
Dec 16, 2006
194
poole dorset
right guys in going to be hopefully fitting some new parts to my 69' bay
got some porsche brakes and a set of original 15" FUCH's to go on the bus
i need to know what size tyres is recommended to fit so i dont knock my speedo out
plus the best place to buy them too
many thanks in advance
What are stock tyres? 185/65 R14?
If so 195/55 R15 are roughly the same rolling radius.
Sorry, they were 185 R14 - closest is 195/65 R15 and will show 2-3% faster
Here you can compare several sizes at the same time!
http://www.1010tires.com/TireSizeCalculator.asp
But trimming your speedo isn't that hard.
Gadget Boy said:
also if you fit 195s u WONT fit them under ur rear arches either 185s MAX :wink:
Doesn't that depend on what offset the wheels are? Or is it tight under there?
My westy hasn't landed yet but I have 5.5 Fuchs and a pair of 205s from another car to go on....
well not sure what these fuch's im getting are yet
195 would be my max really
will see how they fot with the tyres they have on
:lol: they are 225/60/15
You might want to check the 'Tire Sticky' on http://www.thesamba.com to avoid problems. 185R14 was, I believe, 185/80/14 so check with care. Also check the tyre weight rating. You should NOT be running car tyres on a vehicle that does not specify them. You may get away with it, but the downside is not pretty!
Al
