Fortunate Son said:just realised you probably want wide 5 ET
sorry
Fortunate Son said:Mike
39mm
Checkout:
http://www.hrps.demon.nl/jwbus/T2-tires.htm
Andy
Johnnyâ„¢ said:smaller ET = more tucked in? the pics a bit confusing....
Johnnyâ„¢ said:so the higher the ET the more the wheel looks tucked in under the arch? or vice-versa?
'67 BAY said:Mike, think standard is about ET 35.
MMMC said:Can I ask Kempy - what was the conclusion... cause this has confused the hell out of me! I'd like to stick sprintstars on mind but just want to bolt them straight on...am I playing with fire or is that cool according to your figures above? Cheers dude
Johnnyâ„¢ said:i wanted to fit these:
Flat4 Slot Mag ET23 The clearance from stut housing to the inside of the wheel will be 12mm MORE The outside edge of the wheel will EXTEND an extra 12mm
with dropped spindles. By the sound of the ET plus the increased track on the spindles it will be a tight fit on the front... would i need to go narrowed to be safe?
kempy said:Johnnyâ„¢ said:i wanted to fit these:
You are ok to bolt straight on, but you will have to consider the tyre size.
Also you need to take in to consideration the weight when you are in the van as it will drop slightly loaded.
The last thing you want is the tyre hitting the body when you go over bumps. As stated I also prefer the wheels to sit in as much like stock.
Some people fit a slightly narrowed beam to allow for the extra offset, and when done the wheels sit similar to the originals.
I too like the slot mags and even more after reading the latest Volksworld.
The panel van looked great and the wheels appeared to tuck in without a narrowed beam as there was no mention of one.
It was this that made me look further as to how various wheels would fit against the originals.
I honestly thought that wheels with an ET23 would sit further in as i never compaired.
I want to create the look of a slighly narrowed beam without fitting one if thats possible. Looking at the offset of the wheels the only way is to fit 4.5" fuch's without the use of adapters.
