Max Power
Should be a pic here if not why not?
[/img]
Max Power said:hooray who the man
[/img]
I see some of your pics on another thread and noticed the reg was similar,I am in Dover and bought the van locally.aogrady said:Max Power said:hooray who the man
[/img]
Hi!
That's a snap! Nearly the same reg too! Though yours looks mint, mines erm, "used"
Where are you from?
Cheers!
Alistair
Max Power said:Not sure what is next,I have owned it 2 1/2 years, just looking foward to the summer and enjoying a few local trips in it.I have just finished putting new ball joint boots on and cleaning and painting all the bits I removed in the process,trailing arms,backplates etc.Put new shoes on the front as the osf overheated last year driving out of St Davids on our way home from a wet but lovely Pembrokeshire and showed signs of the lining cracking,this was the last part of the brake overhaul as I have already replaced rear flexis(bulging),shoes(lining came off and locked the wheel solid luckily still on drive),cyls(found weeping cyl),hb cables(starting to fray) and master cyl(would not bleed up).
I have done a fair bit over the last couple of years,started by getting the lights to uk(ish) spec the flashing stop lights confuse most people,taking out the dash scuttle panel and painted satin black and fitted a Cobra alarm/immobiliser while I could get in and run the wires easier,Took the screen out and repainted the aperture waxoled and resealed it,got hold of a few missing interior bits such as the arms that hold up the pop top,the fabled stool,the lid and hinges on the sink, still need a tap.Had a few bits chromed,wiper arms,and poles that support the tables and the bunk clips on the A and B pillars.Put the finger plates on the cab doors as the missus rings and nails cause havoc with the paintwork.Stripped and polished the louvre windows with new seal kits from go westy which I was pleased with the results.Put on the side step and 4x 185/15.
I think next in no particular order powder coat wheels,repair steering wheel (if i can get it off),change floor covering in the back,sort out the gearbox whine,the fuel gauge reads 1/4 lower than actual,the wood panel roof has slight distortion? oh and keep on waxing it.The thing with owning one of these is there is always somethig to do.It soon adds up what you have spent but it is a joy to own.Just seen the thread about your van,where were the interior light switches from?
