Today when I slammed the driver's door (window was down) there was a clunk noise and the window would no longer wind up.
I took the door-card off and quickly realised the the channel that the glass sits in had come detached from the bracket, which was bolted to the lifter thingy. I have improvised a fix by putting a longer bolt in the bracket that supports the channel, the channel now sits on this longer bolt and hopefully stays put - the existing bolts will lift the glass, but as they are quite short the glass will easily fall off.
Anyway, I have found a replacement lifter channel, but the site says I may also need a lifter channel seal. Anyone know what the seal is for, I can't see a seal in the existing channel?
![](https://proxy.imagearchive.com/562/562c3024becccd4ec4bb94100ffa6901.jpg)
