Haveacamper said:Out of interest, when the bus is sat on the ground (i.e. the chassis on the ground) how far into the wheel arch will the wheel sit? from that last pic it looks like the spring plate is a lot lower than the bottom the the tyre(tire) implying that you wont be able to get quite as much tucking of the wheel?
squareweave said:I've done a 1" beam raise on my Sierra 71. From the research I did before embarking on the raise is you go 1" or go big because you run into too many problems with shift linkage, heater cables, steering etc. I had side plates that accommodated the 1" raise rather than molesting my frame. I believe Rob B on here did a link pin beam raise on his 72.
