Yes bud, good move, you knows it makes sense. I’ll probs try to get down the yard in the morning, give me a shout if you’re about.
Ozziedog,,,,,,,,,,see Nick and them boys.
Thanks for the heads up. Viton seals are a no-no for rotating parts apparently, in the corvair world anyway, really not sure why mine only last around 4-5yrs but I’m guessing they are Chinese origin. I can’t get them in the uk so rely on parts suppliers in the USA who will ship internationally. The seal kit I have came in about 2yrs ago so I know are fairly new. Agree with vintage nos rubbers parts thoughHave in mind before putting all your effort into fitting seals that were bought years ago is that rubbers have limited recommended shelf lives; initial storage & then a shorter extended period if still looking OK.
Times vs rubber type can be found online. Times are best case scenarios, assuming no UV exposure, using cool dark clean conditions.
Most seals for oil/grease are Nitrile which has an initial storage shelf life of 7yrs. Fuel seals made of Viton type rubbers are more resistant so 10yrs initial storage shelf life, as is EPDM rubber which gets used with certain brake fluids seals.
Whenever I see NOS brake hydraulic parts up for sale I always wonder how those vintage OG seals will perform once pressed into actual service.
So it’s worth pausing to think before you use a borderline aged seal kit, or to get fresher ones, before you put all the blood sweat & tears in.
In my day job we make plenty of viton rotary shaft seals for some big names, so the Corvair viton remark is puzzling.Thanks for the heads up. Viton seals are a no-no for rotating parts apparently, in the corvair world anyway, really not sure why mine only last around 4-5yrs but I’m guessing they are Chinese origin. I can’t get them in the uk so rely on parts suppliers in the USA who will ship internationally. The seal kit I have came in about 2yrs ago so I know are fairly new. Agree with vintage nos rubbers parts though
The kit came with new flexi hoses and they fitted the standard copper unions.Looking fallward to ur feed back on the new front brake setup.
Did the flexis fit straight onto new calipers? Have you got a servo fitted?
Anyway looks great.
You should speak to Ozziedog as he replaced his when he found a brake issue.The kit came with new flexi hoses and they fitted the standard copper unions.
No servo assist…
I have noticed that the calipers are dragging slightly and after reading something recently I’m wondering if my master cylinder is worn, let’s face it, it’s probably the original one!!
Probably will look at replacing it then everything in the braking department is brand new!
Anyone got any recommendations on a MC?
I replaced mine when had the red 9 put on for similar reason.The kit came with new flexi hoses and they fitted the standard copper unions.
No servo assist…
You will not be disappointed with those brakes…just fitted the same to my ‘68..
No bought a new one…changed everything else so why not…I am waiting on some washers to be able to finish the job and fit the otherside. Are you still on your OG master cylinder?
I’m trying to determine what MC I need for my March ‘70 non-servo bus without having to get underneath seeing as it’s cold and dam out…..N
No bought a new one…changed everything else so why not…![]()
Yes mate , the Q…well that’s what I fitted and works well.Looking at it again, mine has two switches so must this
Might wanna keep the old switches for a bit, if you’re getting one complete with switches. I thought mine only cracked when I took out a switch but in hindsight it was probably the start of the crack that was weeping and not the switch. Some of these new switches have a bit of a bad rep for failing easily. That looks to be the same I have on my RHD 70. While you’re down there, have a little check of the reserve reservoir and its feed pipe along with the rubbers reducers each end which are known to disintegrate once disturbed. Or did you change yours already?Looking at it again, mine has two switches so must this
I Changed that already Oz, think we had this convo re the fluid res on top of the MC....... CheersMight wanna keep the old switches for a bit, if you’re getting one complete with switches. I thought mine only cracked when I took out a switch but in hindsight it was probably the start of the crack that was weeping and not the switch. Some of these new switches have a bit of a bad rep for failing easily. That looks to be the same I have on my RHD 70. While you’re down there, have a little check of the reserve reservoir and its feed pipe along with the rubbers reducers each end which are known to disintegrate once disturbed. Or did you change yours already?
Ozziedog,,,,,,,,,,,it’s never straight forward.![]()
