1776, fresh built, just run in SOLD
moler
Aug 10, 2008
835
Lincs
One freshly built 1776cc motor, just run in.
Case line bored, machined for 90.5mm barrels, full flowed, and chemically cleaned, with standard crank reground and chemically cleaned. This work was carried out by Stateside Tuning.
Web Cam...I'll comfirm the grind tomorrow but it was specifically chosen for a bus,
New followers,
Scat cut to length Cromoly pushrod,
Empi bolt up rocker shafts,
Scat swivel feet tappets,
One piece stainless steel valves with uprated single springs, cromoly collets and retainers,
Fitted in crack and pressure tested OG heads,
Refurbished, match weighted, OG conrods,
Mahle forged & match weighted pistons, and barrels,
Uprated oil pump,
Scat oil pump take off to Scat filter head,
Empi 3 1/2Ib equilizer pulley
Dellorto 40 carbs,
Empi breather,
30hp fanshroud,
Alternator,
Genuine Bosch 009 Dizzy,
Standard fuel pump with pressure regulator,
All built with Elring gaskets,
GT twin tip exhaust with J tubes,
Fleshly powdercoated tinware, (except for 2 pieces, as can be seen in the pics, the rear piece will painted soon)
Currently only has a remote filter, but I have an oil cooler and thermostat, and enough extra hose to pipe it in.
The whole bottom end from pulley to clutch plate has been dynamically balanced,
I have access to an engine test stand so it can be seen running,
£2550 ono
Located near Immingham, North East Lincolnshire
Text me on 07762 282 995, I'll get back to you as soon as I can
Or PM me.
