Oslo_mark69
2165 flat Four Turnkey engine built 2018 prior to my trip around Northern Spain and the Pyrenees estimated since build it has covered about 5000 miles .
Original AB Magnesium Case that has been altered for Full Flow Oil system with additional work to the Oil galleries, opening them out increase flow bearings etc. Gene Berg High flow oil Pump ,and gene Berg Deep sump with a Magnetic pickup .
New 94 mm A1 Pistons with Scat Conrad’s and Teflon Gudgon pins all Balanced to within 1 g of each other. New Scat 78mm Crankshaft fitted to a new Flywheel and Dynamically Balanced with Clutch plate . new Main and Cam Bearings. Petronix Flamethrower 2 Ignition and custom made Leads . Heads have been skimmed and over bored and new valve stems and Valves fitted . High lift Rockers and rods with Scat sprung Tubes All new tinware . New Weber 40mm TwinCarbs (not the ones shown in the Image) fed through pressure regulator filter and electric pump .Vintage Speed Big Bore 42mm Stainless Exhaust and J tubes . Oil breather box venting Case and Stainless Rocker covers Braided Oil lines
serpentine Pulley set up
Price £ 3500 , can be seen running
EEC8AF9C-7BDD-45D9-8684-EE002F8799E2.jpeg2.3 MB
D3FACA4E-6EED-45A6-9D50-08F4D2C5557E.jpeg1.6 MB
C339F0F7-DE5C-4C3C-8E4B-1D99B226E423.jpeg1.6 MB
CB80294D-2C0E-4EE3-8B9E-19F83CC3BEA5.jpeg2.2 MB
99A1E732-ACA9-48F3-88BB-B81EC92EE2D1.jpeg1.9 MB
4FE345B9-4576-45BF-8024-682535F6F457.jpeg1.3 MB
D1A56F8A-3240-4B09-AB5C-F5C46905F534.jpeg1.7 MB
3B2D9707-ED1D-4255-BB5C-70D9E725D29F.jpeg1.4 MB
B8D13909-5DCB-4F3B-B471-DCD66E467FF3.jpeg1.6 MB
0CE5D470-6193-4006-9168-08364FA7FD5E.jpeg1.6 MB
