... while inside the bodyshop, Hugo was fixing this part from the poptop roof inner support. After several years of use, the central tube was starting to be cuted by another part from the support itself.... literally cuted! :shock:
However, witth all the tubes cleaned, this structural flaw became noticed. When I assembled it again I realized that this cut was getting really deep, so I had to fix it before all the support would break in the future and while in use.
First, Hugo needed to clean the inside of the tube:
... and then, using a rod with the same diameter as the inner side from the original tube, he cuted two small pieces, one for each side of it:
