Haveacamper
- Joined
- Oct 2, 2007
- Messages
- 2,073
- Reaction score
- 5
well stripping back to bare metal started around the cab chassis area and anything that looked slightly dubious was exposed. the first bit of patch work that was previously disguised by the beam assembly, road **** and waxoyl was this snobbling bit of welding. although not looking the prettiest it is by far not the worst section of metal to be found on this bus.
a bit of attention towards the gussetting was next, by the front chassis legs up to the front panels. one side was worst that the other and could be saved.
well say saved... may be able to grind the excess weld off and it will be solid enough.
i started to grind the weld flat, hoping that the person who welded it had had the correct amount of penetration. however, close inspection you can see the line of the two bits of metal butting up. this may need to be addressed later...
at closer inspection of the outer drivers side chassis leg (the one with the rust hole near front panel in pevios post) justified that it needed to be replaced before i even contemplated putting a new floor in.
before
so there and then i took advantage of my dad's 30 yrs of welding and fabrication experience and held the camera while he set about removing it
and before i knew it....
...it was no more
this can now used to make a nice template in the same shape as the existing chassis leg as a straight replacement.
with removed we couldnt do much else until the member had been manufactured so we went about seeing how well my new floor pan fitted. ha ha ha. the chap i spoke to at C&C told me slight mods were required for the step and changing over of the LDH-RHD stuff. he didnt tell me that is doesnt fit.
the handbrake pivot on a late floor pan is situated inside the cab rather than under the floor which means the bracketry to hold the pin is also in the cab.
I have to therefore decide whether to go with late bay arrangement of early. after closer inspection of the replacvement pan i am slanting towards the idea of keeping the existing arrangement because the whole braket assembly looks alot more heavy duty (plus looks a bitch to get off lol).
well next on the agenda is obviously to get the chassis leg made and then fit it. also i need to get the hole for the heat riser cut into the floor, which will allow me to get a better idea as to how badly/well the floor fits. if i remember correctly schofield does a panel for the front inner wheel arch which i may need to replace on passengers side (poss whole section) so unsure whether i need to fit this before fitting floor??? anyone?
before
...it was no more
