Well its been a long time since i've updated this thread. initially this was due to a combination of being so busy in work that by the time i got home and had dinner there wasnt much time to get down the van before packing stuff back up again. i was starting to feel that by the time i set my stuff up, figured out where i got to the previous visit i had to pack up. the other reason was because we went through a spell of very cold weather in the evening which, when you are working in a very drafty barn, and lying on the floor alot it didnt make comfortable times. however, since the Volksworld show, my project has come to an end and i am now leaving work at a reasonable time every day. the week that followed the Volksworld show I took off work, before startin my new project in work, and carried my enthusiasm from the show into slingshotting me into gear and doing some good work on the van.
so, i lined up the inner and middle sill O/S with took alot of faffing and tweaking. i spent alot of time lining it up using Loxy's van as a reference.
once i was happy with the location i took the sills off, stripped the black paint off and sprayed them with weld through primer ready for tacking them in place.
i checked the location and stitched the inner sill to the end of the tophat sections and plug welded along the inside of the inner
i then paid my attention to the middle and rear O/S outriggers and the tophats that are attached to them. i had noticed several bad patches and soon appreciated that the removal of the two top hats and corresponding centre chassis section couldnt be taken out until the floor was removed. therefore i thought if i was very careful and zipped out the floor with a 1mm cutter i'd have half a chance of putting it back in. unfortunately this was not the case due to the ever keenness of VW and their spot welds. in every trough of the floor VW opted to put two spot welds on each top hat. in the end i bit the bullet and cut out sections at a time and ended up grinding the spot welds off.
i then went to remove the insulation of the heater channel and was surprised when i opened the insulation and the channel itself fell on top of me
it worked out ok because i was removing the y tube and the heater channel as i will be using J tubes from engine straight to exhaust and using proex piped into the dash.
i then started taking the top hats off and prepping the relevant panels and trials fitting them as i went along. i also started cleaning up and priming the chassis sections in this area.
then towards the end of the week off i managed to take off a dodgy angle that a body shop guy i know put on my chassis to mount my new belly pan on and chipped off old waxoyl. then i primed it ready for bits and pieces of patchwork i would do in the near future.
N/S:
O/S:
here is one of the patches i made for going behind the rear outrigger on the O/S:
that brought me to the end of my week off and i went to brighton with g/f to visit her brother and sister in law. had wicked time. i'm now back to work and i've started makng a few patches in the evenings and fitting some more new stuff to the van
its all going forward and i can see the progress.
NaFe out... for now
