Early Bay stuff, from a scrapped 68
Also some beetle and split bus stuff below
Bay
68 bay rear IRS arms £50
68 bay steering idler arm RHD, £FREE
Beetle
Split window bug rear window section, outer skin only (I needed the inner skin), small section of one window surround removed (RHS I think), to the gutter either side and has the grill complete, about 5” up the roof from the windows £150
Stock 1600 crank, needs a regrind, unknown history £FREE
Double IRS spring plates and end caps black powder coated £30
Urethane doughnuts for the above, used for short time, outer ones £5
Early Ghia torsion bar end caps, large doughnut type £20
Beetle blade bumper brackets, front and rear, gen and repro, the one with the towing eye is genuine and in vgc £30 the set
Blade bumper spacers (between bracket/iron and the bumper, genuine full set £20
Blade bumper over-riders, pair, one may be gen, slight dings and scratched, will polish out I think £10
Pair Early/Split bug grooved window winder handles, pitted, £20
Bug Gear box cradle, stock, £FREE
Urethane bushes for an HD anti-roll bar to fit a ling and link pin bug front beam £5
Type 2 gearbox 091 output flanges. To upgrade a bug IRS gearbox when using the rancho super-splines £30
Modified stock IRS driveshafts, the shoulder on one end of each has been taken back to allow the fitting of T2 CV joints with circlips on one end, will fit the above flanges £30
Disc Brake Pads NOS, single pin type, p/n 111 698 151 A £15
Bay
Beetle
