'69 bay. Difference between front and rear shocks?
davelarue
May 4, 2009
21
I have bought 4 new front shocks...do i need special ones for the rear? Can i make it work?
Thx,
Dave
I'm not sure if you could make it work or not because I think rear shocks are longer and frimer (because of the weight at the back) and they may not fit properly and cause something bad to happen...
blimey... :shock:
uber cool said:
front are much shorter, so unless you're slammed the arse off it I'd guess they wouldnt fit.
Two splines is about right. ;) :mrgreen:
What do you mean?
Mine is down two and has front shocks on the rear.
Joval, your probably right, i'm only down 1 spline, was probably more thinking about the difference in extended length compared to compressed. Do you need to unbolt the shock (lower mount) to change the rear wheel!
