Karmann70
Steve B said:Nice and straight Drop Gates pal! How much did they set you back?
You would never believe me if I told you . Let`s just say I had a right result
Karmann70 said:Steve B said:Nice and straight Drop Gates pal! How much did they set you back?
You would never believe me if I told you . Let`s just say I had a right result![]()
Karmann70 said:Ok , here`s what it takes to get the rear centre caps to fit :
Standard centre cap on the left , centre cap with 3mm machined from it on the right:
Next , on the left , standard hubnut , on the right hubnut with 3mm machined from it :
Next job is modifying the Type 2 Detectives front beam . Steering stops are being welded on and some strength being put back into the side plates where the logos have been laser cut in . Pictures soon .
Steve B said:Next job is modifying the Type 2 Detectives front beam . Steering stops are being welded on and some strength being put back into the side plates where the logos have been laser cut in . Pictures soon .
