leon said:Apart from the wiper holes not lining up, was the panel a good profile? It certainly looks to be. I've ordered one for a job because I heard they were far superior than anything else on the market.
Nice job btw.
Haveacamper said:Awesome OG paint here!
I was wondering, the wheels you are running are different to mine, but I was wondering about what static clearance you have on the rear between your drive shafts and the chassis rail and also the semi trailing arm and the chassis?
I'm running 205 45 R17's so it may be an illusion that you are lower then me due to more of the alloy tucking into the wheel arch.
Haveacamper said:maybe there isnt much difference...
i was going on the amount of wheel you had under the arch. glad you are going to notch the chassis a bit for the drive shaft as mine is pretty close and yours looked a bit lower. just thought i would check to make sure you had this in mind
looks good, whatever it works out to be hehe.
squareweave said:Nice looking bus you have there!!
