mattp said:
You can buy new spindles and king/link pins / seals but the spacer and thrust washers are more elusive; you'll also need the leaves and torsion arms
You'll be wanting these shipped to Vancouver then?
Hi matt
what spacer and thrust washer :?: are you saying that you cant just put your 72>hub straight onto the brazilian 96 spindles :? I was lead to believe they would be a straight fit, and all you would need then is the later disks, calipers,caliper bolts and pads...Cheers..Dave
The only place I've found who make them(dropped) is http://transporterhaus.de/index.php?option=com_content&task=view&id=20&Itemid=163" onclick="window.open(this.href);return false;
